Tagging all features with an attribute
  • Mar 8, 2013 7:16 PM UTC
  • 62 views
owen
Me again. I want to use the date and time the workspace is run as the output file name.
At the moment, I am using a creator, timestamper and featuremerger to add the datetime attribute, then using fanout dataset on the datetime.
This seems a bit of a clumsy way of doing it, as the featuremerger is slow when processing lots of features.
Can anyone think of a better way? Really I want to tag all features with the same value. I could do this by creating a published parameter, but cant think how to populate it with date/time.
Thanks,
Owen
davideagle
Forum|alt.badge.img+21
  • Mar 8, 2013 7:59 PM UTC
Put a Creator right at the front of your workspace (create 1 feature and ensure Create At End is set to No, so the Create is the first thing that happens) with a Timestamper going into a VariableSetter. That will set a variable to the first few moments after the workspace was triggered to run.
Then do stuff...
...and at the end use a VariableRetriever to get your value and pin it onto 1 or more features and use it as the attribute to fanout on. See below:
fmelizard
Forum|alt.badge.img+22
  • Mar 9, 2013 8:13 PM UTC
Hi Owen,
Creating the date/time on the features (and formating it accordingly) prevents the merging.
Hope this helps.
owen
  • Mar 11, 2013 11:30 AM UTC
GoldenRetrievers! Thanks dave.
Itay- yes you're right, and I tried that to begin with, but it wasnt giving me a unique date/time value, so had multiple fanouts for each minute, etc.
  • Mar 11, 2013 12:37 PM UTC
Hi Owen,
You could use a scripted published parameter as the feature type name. The following Python code returns the date & time:
import datetime
now = datetime.datetime.now()   # get date & time
return now.strftime("%Y%m%d_%H%M")   # format the time string
In the Feature Type Properties enter as FeatureType Name: $(NameOfThePublishedParameter)
