Switch from External Monitor to Laptop screen makes fonts and icons really tiny
  • Feb 28, 2025 9:31 PM UTC
  • 93 views
vxn43
Forum|alt.badge.img+20
I disconnected my external monitor to work on my laptop (not external monitor) from a different location. When I open up my FME Form workspaces, the transformer parameters font and icon sizes are really, really, tiny.
I saw the way to fix it was in FME Form go to Tool - FME Options - Appearance - Advanced Option and check “Enable automatic scaling for High DPI Monitors”. I have enabled this, closed FME Form, and re-opened it. I have unchecked it and did same. Nothing seems to make a difference.
Is there another way? I am using FME Form 2021.2.0.1.
Best answer by milo89
Hi ​@vxn43,
You might want to look at the scaling settings on the Windows side also. I haven’t had the exact same issue (but similar) and last time I found the fix between the scaling override and resolution settings.
milo89
Forum|alt.badge.img+26
  • Mar 4, 2025 5:39 AM UTC
Hi ​@vxn43,
