stream order in feature caching partial runs
  • Jul 8, 2019 7:59 PM UTC
  • 87 views
jdh
Forum|alt.badge.img+41
Has anyone else had issues with feature order in partial runs when there are two parallel streams?
Example a SpatialFilter set to Filters First
If I run the entire workspace everything behaves as expected.
If I Run From This on the SpatialFilter, all the filters are rejected as `EXTRA_BASE_FEATURE' and all the Candidates fail (due to lack of filters).
fmelizard
Forum|alt.badge.img+22
  • Jul 9, 2019 7:08 AM UTC
Hi @jdh I've reproduced the problem with FME 2019.0 and 2019.2 beta and have filed FMEENGINE-60677 about this. It's likely that any transformer which depends on feature order is affected for partial runs. Thanks for letting us know!
jdh
  • Jul 9, 2019 1:59 PM UTC
I can confirm I've run into issues elsewhere, the SpatialFilter was simply the easiest to see what was going on.
