SSL Cert expiration notification using FME?
  • Feb 11, 2026 4:25 PM UTC
  • 75 views
vxn43
Forum|alt.badge.img+20
Does anyone know if FME can be used to notify via email when one or more SSL certs are due to expire. I have a boatload of SSL certs whose expiration dates I keep track of using a spreadsheet. Just wondering if FME could make it easier? The OS I use is Windows Server 2022.
Best answer by hkingsbury
You could setup a process that runs daily(? or more frequently) that reads the spreadsheet you have and checks if any of the expiry dates are within a defined time window.
For those that are within the time window, an email can then be sent t alert you that the expiry is coming up.
Here is an article on sending emails:
https://support.safe.com/hc/en-us/articles/25407425027341-Sending-Email-in-FME-FME-Workbench-vs-FME-Flow
hkingsbury
Forum|alt.badge.img+73
  • Feb 11, 2026 6:11 PM UTC
vxn43
  • Feb 11, 2026 6:25 PM UTC
Thanks. Yeah I figured I could do that. That seems the easiest way. I will do it.
