SQL Server Reader 2025.2 - possible to read only attribute fields and not the geometry
  • Sep 22, 2026 7:17 PM UTC
  • 46 views
annette2
Forum|alt.badge.img+11
With the new SQL Server Reader is it possible to simulate the older non spatial reader?
I have 3 million records with line geometry.
I only want to read the attribute information and not the geometry.
I can’t spot how to do this in the 2025.2 Reader.  Is it not possible or have I missed something simple?
Thanks,
Annette
hkingsbury
Forum|alt.badge.img+73
  • Sep 22, 2026 7:58 PM UTC
You can use the SQLExecutor instead. That will let you use a full SQL SELECT clause to read in your data
annette2
  • Sep 23, 2026 11:34 AM UTC
Thanks Hamish!
