split upto specific count
  • Dec 27, 2019 6:20 AM UTC
  • 26 views
rakeshreddy0996
I have source with 10 L count like below
I need to select Upto 5L points within source,
I have fields like Object ID and ID both are same and those starts with numeric 1.
Note: should select from one side
  • Dec 27, 2019 9:01 AM UTC
I'm not sure I understand what you are trying to achieve, but generally:
"I need to select Upto 5L points within source,"
Use a Tester to split with < and >. If your data is a string where the numerically sortable part is combined with other characters, use the @Substring function or a regex (\\d+) to pull out the numeric part.
"I have fields like Object ID and ID both are same and those starts with numeric 1."
If needed, use these IDs with a Sorter and/or the Group By function.
"Note: should select from one side"
Use a Sorter on the X coordinate to read and manipulate the features in the desired order.
Hope this helps, otherwise you might need to describe more closely your type of data and the desired output. :-)
