Set published parameters by another workspace
  • Nov 15, 2019 8:29 AM UTC
  • 16 replies
  • 132 views
whkarto
Forum|alt.badge.img+14
Hi Guys,
I'm looking for a possibility to set published parameters of a workspace by running another workspace. My scenario is as follows:
  • I've a set of workspaces with a lot of published parameters in a repository folder
  • for some users, these workspaces are copied from my repositors to user-folders
  • inside these user-folders the published parameters must be set to different values workspace.
Copying the workspaces to the user-folders is done by a workspace to avoid interactive work. But I can't figure out if the second part of my task (definition of the published parameters) can also be addressed to any FME functionality, or if I have to do this manually.
To be 100% clear at this point, usage of a batch-command or a Workspace Runner to set published parameters at runtime is no option in my case! I must be able to run the user workspaces in FME Workbench without any tweaking of the published parameters, except input/output path.
sigtill
Forum|alt.badge.img+25
  • Nov 15, 2019 8:38 AM UTC
An option might be to create a PRIVATE Parameter with choice and alias.
And then at runtime you fetch the FME_SECURITY_USER parameter (not sure about the name - but I think there is a parameter that gets the username of the user that runs the workspace)
And then you can "select" that path in the workspace by saying runninguser = find correct choice.
Not sure if this helps @whkarto ?
Full list of parameters and description can be found here: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/!Transformer_Parameters/FME_Server_Parameters.htm
itsmatt
Forum|alt.badge.img+48
  • Nov 15, 2019 10:19 AM UTC
Ohh this is cool, I'm going to make some user specific office pranks. :-D
Forum|alt.badge.img+63
Please share :)
sigtill
  • Nov 15, 2019 11:03 AM UTC
Make all the workspaces run by your boss, with a fail message :)
itsmatt
  • Nov 15, 2019 11:45 AM UTC
Yes, or send him here http://tiny.cc/ffabgz
I wonder if we can build a RickrollDetector custom transformer...
whkarto
  • Nov 15, 2019 12:01 PM UTC
@sigtil, interesting idea, but I it's going to be quite complicated if there are several parameters to be set with multiple users. I had hoped for some sort of look up table solution where I can set up the proper configuration in some external software (e.g. Excel) and use the published parameter name as join attribute. That way I don't have the need to edit the workspace itself for every new client/parameter
sigtill
  • Nov 15, 2019 12:26 PM UTC
This got me thinking - and since it is friday - ENJOY :) https://hub.safe.com/publishers/sigtill/transformers/webpageopener
itsmatt
  • Nov 15, 2019 12:41 PM UTC
Blast you beat me to it! Well here's the RickRoller: https://hub.safe.com/publishers/virtualcitymatt/transformers/rickroller
Enjoy Pranking
sigtill
  • Nov 15, 2019 12:46 PM UTC
Enjoy Pranking
You can use the link to my Custom transformer inside your Custom transformer. Then your RickRoller can benefit opening it on multiple browsers. Well, time for a beer and weekend now. Have a nice weekend!
itsmatt
  • Nov 15, 2019 1:18 PM UTC
I mean, at the end of the day FME workspaces are just text files. You could try with the txtfile reader/writer to replace the places needed.
But I would guess this could end up being more work than simply opening the workspaces and setting them specifically
sigtill
  • Nov 15, 2019 1:25 PM UTC
Then I guess you can use a python startupscript to read a "settings file" in the users folder or something?
https://knowledge.safe.com/articles/59997/startup-python-scripts-in-fme.html
Forum|alt.badge.img+54
  • Nov 15, 2019 1:36 PM UTC
If you want to have a 'helper' file for each user, you could go down the route of using a scripted python parameter to read a csv file and create a dictionary as a global parameter
Then further scripted parameters to retrieve all the relevant parameters
whkarto
  • Nov 15, 2019 1:45 PM UTC
I've already worked on this approach and am quite sure that I could do it that way. But if I simulate this manually with just one parameter and do a file compare in notepad++ alot more lines than expected are highlighted. So I'm absolute not sure If I can guarantee file integrity! Maybe someone form Safe could comment on this.
itsmatt
  • Nov 15, 2019 3:52 PM UTC
I think this is why FME doesn't really work with the Git/versioning workflow. They are working on it though
itsmatt
  • Nov 15, 2019 4:06 PM UTC
https://hub.safe.com/publishers/virtualcitymatt/transformers/3dclipper-notproductionready Mwahahaha!
