Set Insert into identity columns for all writter types
I have SQL Server Non-Spatial writter with ~80 tables (features). How can I set to insert into identity column for all features and Key column, too? It is same column name for all features.
Is there a way to do this, without setting to every feature separately?
Thanks!
Best answer by david_r
if you mean the feature type properties, there is a button on the bottom left "Apply to..." that can be used to update many/all feature types in one go. Very handy.
David
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • August 15, 2014
David
  • August 15, 2014
David,
great thanks. Good answer, and very quick.
I didn't see it. :D
Aleksandar
