Scripted timestamp parameter
  • Mar 12, 2014 10:06 AM UTC
  • 6 replies
  • 180 views
davideagle
Forum|alt.badge.img+21
I've used a method in the past with a WorkspaceRunner to pass a timestamp value into the log file name parameter of a second workspace to ensure that I always get a unique logfile for each rn of the same workspace. But, that's only any good when I can trigger the process in this way. Right now, what I want to be able to do is to use a scripted parameter ideally to generate a unique log file name that is say a concatenation of the workspace name and the start time so like: FMEBatchRun_2014-03-12T12:01:52.log.
Is a scripted parameter the best option for this and if so, can anyone help me with the syntax as I'm not much good (any good really) at writing python...
Thanks, Dave
Best answer by takashi
Hi Dave,
This is an example. Colons (:) cannot be used in a file name.
# Scripted (Python) Parameter Example
import time
d = FME_MacroValues['FME_MF_DIR'] # directory path
w = FME_MacroValues['FME_MF_NAME'] # workspace name
t = time.strftime('%Y%m%dT%H%M%S') # timestamp
return '%s%s_%s.log' % (d, w, t)
Hope this helps.
Takashi
  • Mar 12, 2014 10:41 AM UTC
Hi Dave,
import time
Hope this helps.
Takashi
  • Mar 12, 2014 10:50 AM UTC
Hi Dave,
I'd say a scripted parameter is perfect for this. Here's a Python script that should do the trick:
import fmeobjects
from datetime import datetime
now = datetime.now().strftime('%Y-%m-%dT%H:%M:%S')
workspace = FME_MacroValues['FME_MF_NAME']
return workspace + "_" + now + ".log"
David
  • Mar 12, 2014 10:51 AM UTC
Good catch on the colons, Takashi!
davideagle
  • Mar 12, 2014 11:18 AM UTC
Gentlemen - spectacular! Thank you both VERY much for the rapid service!
Cheers, Dave
  • Mar 13, 2014 5:43 AM UTC
P.S. The workspace name (FME_MF_NAME) generally ends with the extension ".fmw", it may be better to remove it. And the created log file path may conflict with an existing file even if it contains time stamp, when the previous job was completed in less than 1 second. I tried improving the script in consideration of them. For your information.
# Create log file path with time stamp.
import time, os
t = time.strftime('%Y%m%dT%H%M%S') # time stamp
# If the workspace name ends with ".fmw", remove it.
if w.endswith('.fmw'):
    w = w[:-4]
# If the expected path conflicts with an existing file,
# append sequential number to avoid overwriting it.
base = '%s%s_%s' % (d, w, t)
path = '%s.log' % base
n = 1
while os.path.exists(path):
    path = '%s_%d.log' % (base, n)
    n += 1
return path
salvaleonrp
Forum|alt.badge.img+23
  • Jan 14, 2020 10:44 PM UTC
Instead of using the workspace filename, can I use the ProcessID instead?
