Save AttributeCreator parameter
  • May 1, 2013 2:16 PM UTC
  • 54 views
philippeb
Forum|alt.badge.img+23
I don't think that it is possible right now but with the new AttributeCreator adding the TestFilter and StringConcatenator, It would be cool that we can save our conditional values for an attribute or all of them.
I have made a list of filters and concatenate strings into it, but if I would like to reuse it into an other workbench or just to be sure that all the work I have done into this transformer is saved (I have made an invalid test into the AC and all my work was gone after running my workbench! Hopefully i had the undo button!), I would like to have a file that I could select to load all my parameters rapidly.
That was my suggestion of the day. Thank you.
sigtill
Forum|alt.badge.img+25
  • May 2, 2013 6:48 AM UTC
Hi Philippe!
Have you considered using the SchemaMapper for this instead of Tester and TestFilters?
http://fmepedia.safe.com/articles/Samples_and_Demos/Mapping-Schemas-using-SchemaMapper
philippeb
  • May 2, 2013 12:46 PM UTC
No, but thank you, I'll check it out!
Honestly I never used this transformer before.
