S3 connector unable to download files
  • Nov 29, 2024 8:18 AM UTC
  • 107 views
nedwaterman
Forum|alt.badge.img+9
Morning,
I have access to the bucket and can read files. However, when I attempt to download a file I receive the following error:
My admin insists I have the correct credentials, and I can download this file using WinSCP. Are there are settings I might be missing on the connector?
saraatsafe
Forum|alt.badge.img+13
  • Dec 4, 2024 7:27 PM UTC
Hi ​@nedwaterman, would you be able to confirm that your web connection is working? You can view your web connection by navigating to Tools > FME Options > Web Connections and checking your credentials. It might also be worth trying to create a new connection from scratch.
Another thing you can try is specifying your Region in your S3Connector. This is an optional field but filling that out can help remove any latency in your connection.
nedwaterman
  • Dec 9, 2024 11:20 AM UTC
Thanks Sara  - i have fixed the issue. Not a FME problem, just that the download file was being blocked by security. All fixed now!
