Routing a Workspace in a Workspace Runner
  • Sep 29, 2017 3:39 PM UTC
  • 56 views
In FME Server 2017 you can route a job to a specified engine by specifying the tag for that engine in the Job Routing Tag box in the Advanced panel of the Run Workspace dialog. However, I am calling the workspace from a workspace runner using the FMEServerJobSubmitter tool.
There is no facility in the workspace runner to enter the job routing tag. Also, when I publish the workspace runner to FME Server, there is no place to put in the job routing tag. I tried setting the FME_SERVER_REQUEST_PARAMETERS parameter to "tm_tag=my_engine_tag1" but it still failed when I ran the workspace runner because the workspace did not route to that engine.
Is there a way to set the job routing tag either when you publish the workspace to FME Server or when you call the workspace from the FMEServerJobSubmitter?
  • Sep 29, 2017 3:50 PM UTC
There a way to tie a repository to a tag, maybe this is the way to go.
Another solution may be to use a REST call instead of a workspace runner to launch your workspace.
courtney_m
Forum|alt.badge.img+23
  • Sep 29, 2017 3:53 PM UTC
In the FMEServerJobSubmitter (FME 2017+), if you click the down arrow next to Advanced, there is a box where you can set the Job Routing Tag.
  • Sep 29, 2017 4:30 PM UTC
Yes, that works. Actually the Job Routing Tag box is in FME Desktop 2016 FMEServerJobSubmitter as well. I just didn't see it as it was in the second screen.
courtney_m
  • Sep 29, 2017 4:31 PM UTC
Perfect! I'm glad that helped!
