RegEx to get the first letter of each word. Works in search, but not in SubstringRegularExpression
  • May 13, 2024 3:24 PM UTC
  • 364 views
tnarladni
Forum|alt.badge.img+24
I’m trying to create a new value based on the first letter of each word in a string. I tested the regex ‘\b(\w)’ and the returned value is correct, but when I used that regex in the @SubstringRegularExpression(), it only returned the first letter of the first word.
@SubstringRegularExpression(@Value(ID),\b(\w)) where ID is “MARKHAM RD/ORANGE BLVD, SANDFORD”. You can see in the regex editor, it is correct.
This is the result of the substring
geomancer
Forum|alt.badge.img+71
  • May 13, 2024 4:33 PM UTC
SubstringRegularExpression doesn't work with capture groups, which your regular expression does.
Use a StringSearcher, enter the name of a new list under Advanced, after All Matches List Name.
This will create a list of all values that meet your regular expression.
Next use a ListConcatenator to join all values of the list in a single variable.
danilo_fme
Forum|alt.badge.img+58
  • May 13, 2024 4:51 PM UTC
great solution!
