Readers, data types and auto format
  • May 20, 2026 7:47 AM UTC
  • 53 views
edmjoe
Forum|alt.badge.img+7
I have this data that I want to be treated as immutable (read as strings) in the format CSV (but i suspect that this issue is true for other formats as well?) but FME keeps auto format it to a different format. I think this started with FME 2024 or possibly 2023. Since then I’ve somewhat changed methodology for new work spaces, but yesterday a revisited an old WS and got reminded of this source of frustration. I hope that someone can cure this case of “excel-autoformat-hell” with a solution or an explanation? I really don’t want my data changed automatically in any shape or form.
Example.
CSV-file states that attribute “Datum” has the value ‘2026-05-20’ FME (CSV) reader keeps format it to  ‘20260520’. Even if i manually change the attribute to data type string or varchar FME still formats the date according to above.
crystalatsafe
Forum|alt.badge.img+32
Hi ​@edmjoe
Our development team is currently looking into this (internal reference: IDEA-2389), I'll make sure to keep you updated on the progress.
The best workaround for now would be to use a DateTimeConverter and set the output format to %Y-%m-%d (ISO date).
edmjoe
  • May 22, 2026 8:47 PM UTC
​@crystalatsafe Thanks for response. Looking forward to updates. I’m using the dateformat() function or a PythonCaller if I wan’t flexibility   already but I appreciate you’re giving me a tip on a workaround.
cheers!
