read user attributes only
  • Aug 10, 2015 5:33 AM UTC
  • 59 views
In FME workbench, How can I validate READER feature type user attributes name, type and width with the predefined values.
for ex in Arcgis(arcobjects) , i do this by creating a predefined list of fieldnames . i loop through predefined list to check if the fieldname exist ,if yes then  i will read type,width,precion,length using pfeatlyr.FeatureClass.Fields.Field[j].Type,
 pfeatlyr.FeatureClass.Fields.Field[j].Length
pfeatlyr.FeatureClass.Fields.Field[j].Name
similarly how can i achieve this in FME
  • Aug 10, 2015 6:10 AM UTC
Hi
I'm not sure I fully understand, but if you need to validate the input schema, either use a "Schema (any format)" reader (http://docs.safe.com/fme/html/FME_ReadersWriters/FME_Readers_Writers.htm#schema/Feature_Representation.htm%3FTocPath%3DFME%2520Readers%2520and%2520Writers%7CSchema%2520(Any%2520Format)%2520Reader%7C_____3) or a FeatureReader transformer. You will then get one feature per table with a list containing the field names and their definitions (data type and length).
David
  • Aug 10, 2015 8:29 AM UTC
Hi David,
I donot want to loop through features and get values . I want to read only the fieldnames[column name] and their datatype using *.shp files
As u can see in image below ,the navigator pane has 8 fieldnames and their datatype.
i want to read and validate them .
  • Aug 10, 2015 9:06 AM UTC
Hi
Do not use the FILEGDB reader, use the "Schema (any format)" reader. It will only output one single feature containing the schema definition, regardless of the Shape file contents.
David
