PythonCaller input loop
  • Aug 29, 2016 1:56 PM UTC
  • 7 replies
  • 112 views
I have a PythonCaller with an input function as usual.
In this function, I have a list to update.
myList = [toto, tata] if cond1: 	myList.remove(toto)
logger1  myList.append(momo)
logger2 if cond2:
myList.remove(tata)
logger3
myList.append(mama)
logger4
So, I want to obtain at last, myList = [momo, mama]
But, if I check the loggers :
logger1 : [tata] (all right)
logger2 : [tata, momo] (still all right)
logger3 : [toto] (as if the list reseted)
logger4 : [toto, mama] (so not quite good)
I think the problem come from the fact that I have two objects coming in the FME project. Is that right?
How can I save the first change?
Am I missing something?
Best answer by david_r
I suspect this question would be more suitable in a Python forum.
Anyway, it's difficult to help unless you post the whole code and tell us precisely what you want to achieve.
  • Aug 29, 2016 2:10 PM UTC
verdoodtdries
Forum|alt.badge.img+23
I think you are mixing up local and global variables, but please post your whole code so we can see what's going wrong.
  • Aug 29, 2016 2:21 PM UTC
def input(self,feature):
myAnswerField = [('Echelle1', None), ('Echelle2', None)]  if '01' in feature.getAttribute('id_reseau'):
            scale1 = feature.getAttribute('echellesortieplanprincipal')
            myAnswerFields.remove(('Echelle1', None))
            myAnswerFields.append(('Echelle1', scale1))
        if '02' in feature.getAttribute('id_reseau'):
            scale2 = feature.getAttribute('echellesortieplanprincipal')
            myAnswerFields.remove(('Echelle2', None))
            myAnswerFields.append(('Echelle2', scale2))
with this database :
  • Aug 29, 2016 2:22 PM UTC
I thought it was a PythonCaller problem actually. Maybe I misunderstood.
  • Aug 29, 2016 2:39 PM UTC
The way the PythonCaller works is pretty simple and it is coherent with the way Python (and most OOP languagues) work in this type of pattern:
  • Before the first feature arrives: call __init__() once
  • For each feature: call input() once per feature
  • After the last feature has passed: call close() once
You may want to read up a bit on Python objects and particulary on scope, e.g. here. I agree with @verdoodtdries that it looks like a scoping error.
I do not quite understand what you really want to achieve, but I suspect you want to make myAnswerField an object instance variable (rather than a local variable, as it is now). You can do this by initalizing myAnswerField in __init__() and prefixing it with "self." whenever you reference it.
As it is you are effectively resetting (redefining) myAnswerField for every incoming feature, that may not be what you want?
  • Aug 29, 2016 2:44 PM UTC
Ok, I understand. And you both are right for intention in this context. I'll try. Thanks.
  • Aug 31, 2016 12:33 PM UTC
Ok, it's seems that I should have just one feature in the input instead of 2. A colleague of mine helped me on that. So problem solved.
Thanks anyway. I have a better understanding of the PythonCller thanks to you.
