Python Startup Script to Terminate Workspace
I have a Python Startup Script using cx_Oracle library, which calls an Oracle Procedure returning a count value. If the count is greater than 0 then I want to stop the Workspace running.
Wondering how do I go about terminating the Workspace?
Thanks!
import cx_Oracle
# Connect to Oracle and Query the table
try:
    connection = cx_Oracle.connect('user/pwd@orcl')
    cursor = connection.cursor()
    result = cursor.var(cx_Oracle.NUMBER)
    cursor.callproc('check_valid_dataset', (101,result))
    if result.getvalue() > 0.0:
        print 'Terminating: Some datasets are not available'
    cursor.close()
    connection.close()
except:
    print 'ERROR - Python startup script could not connect to database'
  • April 3, 2015
Hi Mark,
Try throwing an exception object. For example:
cursor, connection = None, None
try:
    # Throw an exception if an unexpected condition has occurred.
    if <bad condition>:
        raise Exception('message')
except Exception as ex:
    # Catch the exception and re-throw it to abort the translation.
    raise ex
finally:
    # Clean up resources.
    # I think it's better to call the "close()" methods here, like this.
    if cursor != None:
        cursor.close()
    if connection != None:
        connection.close()
Takashi
  • April 8, 2015
Thanks Takashi.
I had tried using raise to throw an exception but thought I'd badly coded when I saw all the red text in the log. Perhaps I expected FME to halt more cleanly than with the exception.
Updated version:
import cx_Oracle
try:
    connection = cx_Oracle.connect('user/pwd@xe')
    cursor.callproc('check_valid_dataset', (123,result))
        raise Exception('missing data')
except cx_Oracle.DatabaseError as e:
    error, = e.args
    print 'oracle error'
    print(error.message)
    raise e
except Exception as e:
    print e
    raise
finally:
    if cursor != None:
        cursor.close()
        connection.close()
  • April 9, 2015
Unfortunately, I don't think it can be avoided that the red text appears when an exception has been thrown in startup python process.
If you can read the source dataset by a SQLExecutor or a FeatureReader, the "clean halt" is possible with this implementation.
(1) Define a global variable which indicates the condition in the startup script,
(2) Create an initiator feature which has an attribute storing the condition, with a PythonCreator,
(3) Check the attribute by a Tester, and halt the translation if the value indicates the bad condition.
Skeleton:
# Startup Python Script
g_condition = 1 # global variable
if <bad condition>:
    g_condition = 0
# PythonCreator (expose "condition" attribute)
import fmeobjects
class FeatureCreator(object):
    def close(self):
        feature = fmeobjects.FMEFeature()
        feature.setAttribute('condition', g_condition)
        self.pyoutput(feature)
# Tester
Test Clause: condition = 1
- Passed => SQLExecutor or FeatureReader (start the translation)
- Failed => Terminator or do nothing (halt the translation)
  • April 9, 2015
The Tester can also be omitted.
# PythonCreator
import fmeobjects
    def close(self):
        if g_condition == 1:
        else:
            # log messages if necessary.
            pass
  • April 9, 2015
As always you supplied a great solution.
Many Thanks!
