Python Caller - How to set feature as a global
In my python caller script I can not access to feature outside of the function checkViewer(). I would like to be able to access it in the Index() class.
How can I make the feature as a global variable?
import fmeobjects
import json
import matplotlib.pyplot as plt
from matplotlib.widgets import Button
from descartes import PolygonPatch
def checkViewer(feature):
    BLUE = '#6699cc'
    geometry = feature.getAttribute('_geometry')
    geoJson = json.loads(geometry)
    fig = plt.figure()
    ax = fig.gca()
    ax.add_patch(PolygonPatch(geoJson, fc=BLUE, ec=BLUE, alpha=0.5, zorder=2 ))
    ax.axis('scaled')
    callback = Index()
    axprev = plt.axes([0.7, 0.05, 0.1, 0.075])
    axnext = plt.axes([0.81, 0.05, 0.1, 0.075])
    bnext = Button(axnext, 'Garder')
    bnext.on_clicked(callback.garder)
    bprev = Button(axprev, 'Rejeter')
    bprev.on_clicked(callback.rejeter)
    plt.show()
class Index():
    def __init__(self):
        self.feature = feature
    def gader(self, event):
        plt.close()
        feature.setAttribute('check', "yes") #this is not working because feature is not global
    def rejeter(self, event):
        plt.close()
        feature.setAttribute('check', "no") #this is not working
  • June 30, 2014
I'm not familiar with maplotlib, but the feature object probably can be passed to the callback object with the following way:
    # create an index object
    callback = index(feature)
# index class definition
class index:
    def __init__(self, feature):
        self.feature.setAttribute('check', 'yes')
Takashi
  • June 30, 2014
Takashi is right, the FMEFeature object is a native Python object and you can pass it along as such. If you need to access a particular feature later on (outside the PythonCaller), you will probably have to make a clone of the feature and manage it yourself, see FMEFeature.clone() in the docs.
David
