Publishing Web Connections in FME Server 2017
  • Nov 16, 2017 7:31 PM UTC
  • 60 views
Are web connections different from database connections when uploading to FME Server 2017? I have a named connection that I've already uploaded. When publishing, it shows as needing to be uploaded again. But when I try to upload it it says "Named connection already exists". When I uncheck the upload box it says "connection will be unavailable on FME Server". It looks like if I publish the workspace and ignore the "connection will be unavailable" message, it still works. Is this a known issue in 2017.1? I'm using Build 17539. @SteveAtSafe
Best answer by stephen.wong
Hi @aarongundel, does Build 17539 refer to the Desktop or Server version? I want to refer you to this page, indicating known issues, the first one of which (Database Connection Upload via Publish Wizard) is very similar to what you are describing.
https://knowledge.safe.com/articles/40806/workarounds-to-known-issues-in-fme-20170.html
Thanks,
Stephen
  • Nov 17, 2017 1:53 AM UTC
Thanks,
Stephen
steveatsafe
Forum|alt.badge.img+16
Thanks,
Stephen
Hi @aarongundel, apologies for the inconvenience.
Thanks,
Stephen
Stephen, that looks like that's the issue. Thanks for the pointer!
