Published parameter with conditional values
  • Jun 12, 2015 7:41 AM UTC
  • 50 views
geolassi
Forum|alt.badge.img+8
Hi!
I remember FME could set conditional values to published parameters, but I couldn't do it in FME 2015.1. I even found a workspace from 2013, which had a published parameter with a conditional value:
I have no idea, how I did that. Has the function been changed somehow?
  • Jun 12, 2015 10:18 AM UTC
If you create a user parameter from a transformer parameter that has the Conditional Value option, it will have the option. Otherwise, the option will not appear.
I think it's common in FME 2013 - 2015.
Takashi
