Published Parameter as Shapefile name - incorrect attributes attached
  • Dec 10, 2013 5:34 PM UTC
  • 48 views
Hi
I have a project that converts a GML file into 6 individual shapefiles. I have mapped all the attributes from the GML file to different names in the shapefile in order to comply with the 10 character limit e.g -
featurecode > featcode
versiondate > date
Now I want to name the shapefile dynamically from a publish parameter so I used the attribute creator to create a new attribute called "feature_name" with the value:
$(name)_TopographicArea
and this outputs a shapefile with the correct name. so far so good......
The problem is the shapefile now contains multiple additional attributes that I didn't select or want in the resulting shapefile. How do i retain the schema mappings that I made?
Any ideas?
Mike
  • Dec 11, 2013 5:46 AM UTC
Hi Mike,
I guess you are using fanout option on the Shape writer and there are differences among schemas of the 6 writer feature types. If so, I think there are two possible ways. 1) Not use fanout. Create 6 writer feature types and configure schemas (user attributes) separately. 2) Use Dynamic Schema functionality with a schema definition table. You can set "fme_feature_type" to distinguish each destination feature type.   To learn more about the 2nd way, see Examle 3 in this documentation. Dynamic Schema Examples http://fmepedia.safe.com/articles/Samples_and_Demos/Dynamic-Schema-Examples-FME2011
Takashi
dustin
Forum|alt.badge.img+36
  • Dec 12, 2013 1:28 PM UTC
Would an AttributeRemover before the writer work?
