Process timeout at the workspace level
  • Aug 21, 2024 3:53 AM UTC
  • 6 replies
  • 406 views
hkingsbury
Forum|alt.badge.img+73
At the FME Flow (we’re looking at 2022.2 specifically) level, many people will be familiar with the ability to set time outs for queuing and running
Through the API you can also specify these by using the Job Directives: https://docs.safe.com/fme/html/FME-Flow/ReferenceManual/Job_Directives.htm
The scenario that we’re facing is there is an external process (not FME) that is setup to call a bunch of different workspaces depending on what is passed through. This is a process not managed/administrated by us.
Depending on the workspace called, we want to specify the running expiry at the workbench level, of course this could be doing with logic in the external process using tm_ttl/tm_ttc, but that would mean needing to release updated code each time we want to change this.
We’ve tried specifying tm_ttc as a workspace parameter (both published and private) but FME Flow doesn’t acknowledge it.
Talking with @todd_davis we’re both sure you used to be able to do this (specific run time limits at the workspace level).
Have we missed something?
Best answer by hkingsbury
I have made an Idea for this:
https://community.safe.com/ideas/process-timeout-for-workspaces-34637
siennaatsafe
Forum|alt.badge.img+12
Hi @hkingsbury,
I’m asking around internally to see if something similar is possible and update this post if something comes up.
The only thing I can think of is using a FMEFlowJobSubmitter in a parent workspace to run a child workspace and use those parameters.
hkingsbury
  • Sep 2, 2024 2:35 AM UTC
Hi @hkingsbury,
Thanks Sienna, I thought about raising an idea, but I’ll wait to hear back from you
siennaatsafe
Hi @hkingsbury,
I think this is worth raising an idea!
The only other suggestion is to do a datetimestamp, then calculate the time running, if it’s too long then use a terminator, but that’s understandably not a great workaround.
Sorry we couldn’t think of anything else to meet your needs here!
j.botterill
Forum|alt.badge.img+69
  • Sep 9, 2024 7:49 AM UTC
Hi guys, I’ve had some problems with the FMEServerJobSubmitter in previous versions. I have topic published on a child workspace for success or failure. Somehow the transformer doesn’t make these topics run, I have to change to a httpcaller and specify the topics in the directive
itsmatt
Forum|alt.badge.img+48
  • Sep 9, 2024 9:41 AM UTC
you might want to create a new thread - this answer seems unrelated to the initial question.
hkingsbury
  • Sep 10, 2024 8:47 PM UTC
