Problem with where clause in InlineQuerier
  • Jan 17, 2018 5:03 AM UTC
  • 103 views
akheirabadi
Hi All,
I have added two list as input tables to InlineQuerier and have problem with where clause in it.
In Outputs if I create a select query base on one table it works, but I want to use where clause in that query, and after adding any sort of where clause even easy one like (where field = "value"), it is not returning anything.
I want to find records in one list which are not in the other list, with query like this:
SELECT "name","type","fme_feature_content" from Table1
Where "name" in (Select "name" From Table2)
Appreciate for any help.
  • Jan 17, 2018 5:23 AM UTC
What happens when you run the workspace? Does FME log error messages?
erik_jan
Forum|alt.badge.img+26
  • Jan 17, 2018 2:11 PM UTC
This could also be solved using the ChangeDetector or the FeatureMerger transformers.
scyphers
Participant
Forum|alt.badge.img+5
  • Participant
  • Jan 17, 2018 5:19 PM UTC
Are you getting errors in log window about invalid name If the field "name" exists in both tables you might need to qualify the tablespace. FME might not return a result when the namespace is unclear.
Try something like >
SELECT t1.name, t1.type, t1.fme_feature_content
from Table1 t1, Table2 t2
where t1.name in (select distinct t2.name)
order by t1.type
****Update
Oooops.... I just spotted you want recodset NOT in the the other table. Try
SELECT * from Table1 t1
where not exists
( select 1 from Table2 t2
where t1.name = t2.name)
that might chase them out. ;)
gio
Forum|alt.badge.img+15
  • Jan 19, 2018 4:34 PM UTC
Did you add the attributes to the inline query data sets to read.
This happens if you add datasets and then later change or add a attribute not in the sets. (alas not dynamic...)
Check in the columns of the tables if the attributes are there.
The querier does not do this checkin for you, it will let you go ahead until at runtime it reports an error.
Also I assume you did check the letter cases? (had to ask)
Also I found in (2016 version) attribute names with spaces to be an issue for the ILQ. I replace them with an underscore.
