Problem with Batch Deploy after FME_TEMP cleaned
  • Nov 30, 2016 2:31 PM UTC
  • 88 views
A few days ago we cleaned our FME_TEMP env variable directory as we had ~80GB files sitting there. I am now unable to use the Batch Deploy option and get the following in the log;
Starting translation...
couldn't open "{E:/Local Processing/FME_Temp/FME_1480515564385_17256}": no such file or directory
    while executing
open $superBatchFileName "w"
    invoked from within
set superBatchFile [open $superBatchFileName "w"]
    (file "C:/Users/william.allen/AppData/Local/Temp/5/fme-batch-deploy-f14892.tcl" line 14)
Purging temporary files does not make a difference - nor does creating a blank file/folder.
Do I have to change the Temp directory? Any idea how to avoid this - and keep the Temp folder size down?
mark2atsafe
Forum|alt.badge.img+59
That's interesting, well surprising actually. Are you just running a previously generated batch deploy (which I could see might be a problem) or are you generating a new one? Also, where is your workspace saved? I'm assuming it is saved but is not saved in the temp directory?
If nothing in there helps then I suggest contacting our support team: safe.com/support and asking them for assistance. Be sure to send them a copy of any bat/tcl files you saved and let them know which version of FME you are using.
  • Dec 1, 2016 9:13 AM UTC
It turns out that all of our workspaces are failing to batch deploy (new and old ones) on this server. They are give a similar message.
I'll try creating a new temp directory - and will contact support if that fails!
Thanks
  • Dec 6, 2016 5:26 PM UTC
It turns out that the issue was the space in the directory 'Local Processing' changing the environment variable to a directory without a space fixed the problem. The issue was also effecting the Data Inspector - which would launch but wouldn't show any data.
