Problem while using PathReader + WorkspaceRunner
  • Sep 12, 2019 2:42 PM UTC
  • 10 replies
  • 78 views
Hey folks,
After some hours of Googling and of searches on this forum, I'm writing here to solve my problem.
I've built a huge FME Batch to do some stuff on IFC files with some Excel readers, ACAD readers, and CommandLine. But here isn't the problem, that Batch works properly when I run it 'alone'.
Here a quick overview of that Batch :
Everything is ok with that Batch, but then I would like to work with a PathReader and a WorkspaceRunner in order to work with all the IFC files of a folder.
So, I've set up that Batch which is really simple :
With these following parameters :
When I run the batch with a Pathreader and a Workspacerunner it seems to run properly too, but nothing happens then (i-e any files are created at the end of the Writers).
Does anyone already had those type of problems ? Do I need to set up something specific in the 'child' batch in order to run it with a folder reader ?
Thanks to everyone for your future answers,
Best.
Clem
Thanks to the use of spies : an ExcelWriter in a fixed folder, the problem seems to come from the different ExcelReaders. But I still didn't find yet how to fix it.
itay
Forum|alt.badge.img+19
  • Sep 12, 2019 3:33 PM UTC
Could it be that not all the input Excel files have the required feature types ( ei. sheets)?
  • Sep 12, 2019 3:58 PM UTC
Normally each Excel file has only 1 sheet which a table to set some corresponding properties. I'm running out of ideas of what the source of the problem could be
itay
  • Sep 12, 2019 6:09 PM UTC
Would it be possible to share the logfile of the huge workspace?
  • Sep 13, 2019 6:39 AM UTC
The Excel readers can sometimes be a bit finicky, in particular regarding the "Feature types to read" attribute. This is a potential issue if you change the source file without updating the reader feature.
If your workspace might read different Excel files from different locations, my recommendation would be to use a dynamic Excel reader, that way it will always return the contents regardless of what the sheet name is.
  • Sep 13, 2019 7:05 AM UTC
Normally all the Excel files are in the same folder, they just contains different PSET. Each file has only one sheet.
How to set up a workspace runner with dynamic Excel readers ?
Thanks for your answer.
It would be possible, but I don't know how to do it unfortunately.
  • Sep 13, 2019 7:34 AM UTC
When creating the reader:
More info here: http://docs.safe.com/fme/2019.1/html/FME_Desktop_Documentation/FME_Workbench/!FeatureTypeProperties/Merging_Feature_Types.htm
  • Sep 13, 2019 7:48 AM UTC
Unfortunately I already use some single merged feature type.
That's really weird but I think that the problem is something very minor
itay
  • Sep 13, 2019 9:54 AM UTC
You can upload the logfile in the forum (see the upload file button in the menu)
