Possible bug?
  • Nov 29, 2018 3:20 PM UTC
  • 79 views
I've found an odd quirk with FME Server.
When I remove " from a file path on an FME workbench when it's uploaded to the server, the guest role will be able to run the work bench but the admin role won't be able to. This also occurs vice versa when adding " it works for the admin role but not for the guest role.
I am using a direct link to run the workbench but this bug occurs without using the direct link to.
My question is is this intentional or a bug?
Server verison: FME Server 2018.1 - Build 18520 - win64
Hi @josh7322,
Please could you provide some screenshots of the where you are changing this file path to help me try and reproduce the behaviour you are seeing? Is it whilst setting a published parameter or during the file upload process?
  • Nov 30, 2018 10:56 AM UTC
Hi @josh7322,
To answer @RichardAtSafe
-The speech marks are automatically placed around the file path (I remove them manually).
-I can select the work space with both roles but only if speech marks are included or not included. However, the guest role can only access the work space with a direct link and can only run a work space in that Repository.
-The file path runs to a file directory.
With speech marks:
Result:
Without Speech marks:
Result:
This log error pops ups every time the workbench runs it's the same on both roles and for every CSV reader:
Josh
