Polygon M to Polygon
  • Dec 17, 2024 8:06 PM UTC
  • 56 views
ksjohnson
Can you convert a Polygon M shapefile to a Polygon shapefile?
emma.at.safe
Forum|alt.badge.img+11
Hi ​@ksjohnson,
Yes, you can convert a polygon M (assuming you mean measure values) shapefile to a polygon shapefile. FME provides several transformers to handle M values, such as MeasureRemover, MeasureSetter, and MeasureExtractor, which are readily available in FME Workbench. Additionally, there are more specific transformers available on FME Hub.
Once you’ve processed the M values, you can write the result to a shapefile using a ESRI Shapefile Writer.
Hope this helps!
Emma
