Pass parameters to HTTCaller
  • Sep 29, 2023 1:11 PM UTC
  • 62 views
sunsilk11
Hi I would like to make a REST call using FME HTTPCaller to Validate Network Topology as defined in https://developers.arcgis.com/rest/services-reference/enterprise/validatenetworktopology-trace-network-server-.htm
I have obtained the token in the first call, and would like to pass all required parameters in the second call. (see attached)
I am getting error:
This FME Edition doe not recognise the '' function
Any suggestions how the required parameters, inc the token can be passed to fmecaller
natalieatsafe
Forum|alt.badge.img+12
@sunsilk11​ HI there, thanks for your question and for the workspace you provided. I can see that you've encountered an known issue with the HTTPCaller in your FME Desktop 2021.2.3. The resolution to this issue has been applied to FME Desktop 2022.2. Upgrading your FME to at least FME Desktop 2022.2 will get around this bug. Unfortunately, there isn't a workaround for this issue.
Please let me know if you have any questions on the above; I'm happy to discuss further if needed.
