OWX Wellheader
  • April 4, 2024
  • 59 views
bcoshea
Forum|alt.badge.img+4
I have a project to automate creating an OWX file to import into IHS Kingdom Geoscience project. I can manually download an OWX well header file from Enverus Prism. This file is in ascii format and can be viewed in Notepad ++ . I do not see a transformer the can read or write the wellheader.asc file. My guess is I would need to create a custom transformer and then parse the data. Landmark may be the original vendor to use this OWX file format.
virtualcitymatt
Forum|alt.badge.img+38
Yeah that’s essentially what you’ll have to do.
Depending on the structure of the file will depend on what you will need to do. I think FME is a good choice though.
To read the file into FME you can use a Text File reader which can read the data line by line. I guess the data is just line by line with a prefix e.g., HXXX where each of those correspond to some particular field?
