Output a count of zero from the Tester Transformer on failed conditions.
  • Aug 3, 2023 3:34 AM UTC
  • 61 views
Hello All,
I have a Tester transformer that ideally produces no Failed outputs but I want to count the number of Failed outputs, even if its zero. I've tried a few things with no results. The Failed output from the tester doesn't seem to produce any data or if it does, I don't know how to access it.
Thank you,
Kevin
Best answer by tomfriedl
Looking for NoFeatureTester ​
tomfriedl
Forum|alt.badge.img+14
  • Aug 3, 2023 5:09 AM UTC
  • Aug 3, 2023 5:54 AM UTC
Brilliant. Thank you!
