Oracle TO_DATE function into Where Clause
  • December 10, 2019
  • 512 views
philippeb
Forum|alt.badge.img+20
Hello,
I have a table with millions of features. I need to use the Where Clause to extract what I want.
I'm using a Published Parameter to define a date. My problem is the date format into database (YYYY-MM-DD). And Data Inspector tells me it's encoded windows-1252, not string (don't know if it changes something).
I though to use into Where Clause the TO_DATE function to convert my dates.
 TO_DATE('@Value(DATE_into_Database)''YYYYMMDD') => '$(DATE_FROM)'
But it's not working. I get an Unable to execute SQL statement. And I'm not even sure if it's supported by FME because this function isn't into the SQL Date Functions choices. I only have those (the help button sent me there) : SQL Date Functions
Do you have an idea how I could extract those dates ?
erik_jan
Forum|alt.badge.img+18
  • December 10, 2019
I believe the published parameter is a date in char form YYYYMMDD:HHMINSS
So the easiest way would be converting the database date to a char, like this (assuming the DATE_into_Database is an Oracle table attribute):
TO_CHAR(DATE_into_Database, 'YYYYMMDD') => '$(DATE_FROM)'
Hope this helps.
