One HTTPCaller One Session
  • May 15, 2025 11:03 AM UTC
  • 66 views
itsmatt
Forum|alt.badge.img+48
Something I recently learned about with FME is that each HTTPCaller seems to equate to one session - there are most likely a lot of cases where this isn’t true but I had some weird issues recently where a series of calls working intermittently.
The process was creating a document container and then uploading files into it and then closing the container.
I used 3 separate HTTPCallers for this. When testing from FME desktop it worked sometimes and others it didn’t work. I spent a tonne of time trying to debug what was wrong in my POST. Finally it seemed like it was working, I published to Server and directly had issues again.
Looking into the Debug logs I noticed that with each new instance of the HTTPCaller there was a new connection to the service BUT that connection was going to a different IP. The host was using a load balancer to handle API requests.
Turns out my container was being created on one server and my follow up requests were hitting the other server.
After I fed everything though a single HTTPCaller the problem went away.
Creating a session in python is pretty standard and I was wondering how FME handles sessions. To me it seeems like it’s one session per HTTPCaller.
Has anyone else got any more insight?
hkingsbury
Forum|alt.badge.img+73
  • May 15, 2025 10:11 PM UTC
Does the API you’re working with provide you a session token/id/callback or similar to ensure you’re consistently connection correctly?
The only thing I can think of would be trying the save cookies option. Not confident it would work, but worth a try?
