Never Ending Workspace
  • Feb 4, 2020 5:27 PM UTC
  • 10 replies
  • 148 views
jbradfor
Forum|alt.badge.img+7
We are suddenly having issues with FME.exe that are not terminating.
It does not happen every time either, about twice a day (runs every 15 mins for 20 hrs a day) Log shows everything is Successful, but FME.exe is still running.
The workspaces we are having issues with are all using S3 transformers. The upload or downloads are working correctly, but the EXE is not ending. We are running FME(R) 2018.0.0.3 (20180430 - Build 18305 - WIN64). We have not upgraded to 2019 due to an issue we had while testing large file sets. 2020 is in the future, but we need a solution sooner due to a business critical dependency.
jbradfor
  • Feb 4, 2020 7:54 PM UTC
We implemented a hack. I added a Terminator to the end of the flows. The one flow ended with a text file writer, so I had to replace that with a FeatureWriter and then attached the Terminator to that. Will see if this does the trick. Ugly solution, but if it works we can get by until 2020 upgrade and then we can retest.
jbradfor
  • Feb 5, 2020 4:39 AM UTC
Terminator, Did not work.
jbradfor
  • Feb 5, 2020 7:57 PM UTC
We upgraded to FME(R) 2018.1.2.1 (20190319 - Build 18592 - WIN64). Did not work
jbradfor
  • Feb 5, 2020 7:58 PM UTC
We are running Windows Server 2016
andreaatsafe
Forum|alt.badge.img+17
Hi @jbradfor,
How are you running these workspaces on a schedule? Are you using the windows task scheduler?
Since this does not happen everytime the workspace is run, for the times that FME does not completely end, is the workspace running longer than 15 minutes?
I'm wondering if FME is not exiting because the workspace is being triggered again by the scheduling app you are using, which is causing this issue?
Are you able to share a log file of a successfully completed workspace versus one that does not end?
- Andrea
jbradfor
  • Feb 6, 2020 4:41 AM UTC
We are using an Enterprise Scheduling product (autosys) that calls a PERL script which then executes the FME job. Solid approach for many years. We run about 20 FME mappings sequentially every 15 min.
I implemented a Python Shutdown script in the 3 FME mappings (all have S3 transformers in them) that are hanging on us. The script does a Kill on the workspace. Will see if it works.
jbradfor
  • Feb 6, 2020 3:32 PM UTC
Nope, adding the shutdown script did not work. Removed it. I will wait until it happens again and gather all of the logs and take snapshots.
jbradfor
  • Feb 9, 2020 3:29 AM UTC
Today, I tried putting a kill script inside a Python Caller at the end of the flow. Did Not work.
jbradfor
  • Mar 19, 2020 9:54 PM UTC
Upgrading to FME 2019 and upgrading transformers worked
andreaatsafe
Thanks for the update @jbradfor, glad an upgrade to FME 2019 resolved the issue.
- Andrea
