NetCDF writer error
  • Jun 4, 2024 2:18 PM UTC
  • 197 views
gjaguilar
Hello,
I am trying to write several files in NetCDF format with FeatureWritter; but after writing the first one it gives me this error: NetCDF writer: Failed to define variable. The error was 'NetCDF: String match to name in use'
If anyone has experienced this and can help me
First of all, Thanks
Best answer by gjaguilar
Hello
I continued investigating and the error is due to the fact that the netcdf data is in degrees and that an attempt is made to write with NetCDF using a coordinate system in meters.
Thank you so much
ali-safe
Forum|alt.badge.img+24
  • Jun 5, 2024 9:54 PM UTC
Hello, @gjaguilar.
Thanks for posting your question. To assist you better, if possible, could you kindly provide more details about your workflow process, including the file format your reading and processing and screenshot(s) of your FeatureWriter parameters? Thanks!
gjaguilar
  • Jun 7, 2024 7:51 AM UTC
Hello
Thank you so much
