My batch print is not working properly. The workspace runs, but when I try to run batch manually it fails. Saying error determining writer (Translore). Again regular workspace runs properly. Help?
  • Mar 8, 2019 2:39 PM UTC
  • 19 views
jasmus2
jovitaatsafe
Forum|alt.badge.img+11
Hi @jasmus2,
Which method of batching are you using (command line or batch file)? And what format(s) are you writing to? Would you be able to give Dan's answer from this Q&A a try and let me know whether that works for you?
