Multiple workbooks into one based on filename
  • Aug 31, 2016 10:23 AM UTC
  • 104 views
Hi I have a question which I think is simple to answer but I'm struggling and in a rush...
I have a folder with 1000+ excel files all named the same except for a 3 digit code at the end of the filename string, before the extension. I then have two data layers of file for each code. I need to extract the two excel workbooks that have matching 3 digit codes into one workbook, with each of the two data layers going into a separate worksheet.
eg. example files
London_123_Cars_ABC
London_123_Buses_ABC
London_123_Cars_DEF
in this example I need the two files which end in ABC (3 digit code) to merge into one excel file with a sheet containing the 'Cars' data and a sheet containing the 'Buses' data.
i've tried exploders and lists but struggling so any help? the more detail the better, thanks in advance
itay
Forum|alt.badge.img+19
  • Aug 31, 2016 10:30 AM UTC
I would use the fme_basename to extract the digits and group with the aggregator, make sure you are keeping the attributes when doing that .
Forum|alt.badge.img+63
Here's how I solved it.
  1. Set up a reader to read all Excel files in a directory and output a single feature type. I'm assuming they all have the same attribute structure.
  2. Expose the fme_basename attribute. This holds the original filename.
  3. Assuming the filename always follows that structure I've used an AttributeSplitter to split it with the _ (underscore) as split character. This creates a list with list{2} containing "Cars" or "Buses" and list{3} the 3-digit code.
  4. Set up an AttributeManager or AttributeCreator to create new attributes "sheet" and "file" and fill them with list{2} and list{3} respectively.
  5. Set up an Excel writer and use the attribute "sheet" to fill the sheet name, then set the fanout option in the navigator and use "file" for the filename.
Hope this helps. I've attached a template with my workspace and input files.
excelcombiner.fmwt
