Multiple CAD files to multiple File Geodatabase (*.dwg --> *.gdb)
  • Sep 6, 2017 8:25 AM UTC
  • 153 views
Query regarding how to perform the following task:
Need to process the translation from multiple CAD files with dynamic schema to multiple file Geodatabase.(*.dwg --> *.gdb)
for e.g
abc.dwg --> abc.gdb
def.dwg --> def.gdb
ghi.dwg --> ghi.gdb
probably fanout is the process but need guidance how can i do it in best and easy way.
Thanks in advance.
geosander
Forum|alt.badge.img+7
  • Sep 6, 2017 8:38 AM UTC
Yes, fanout is the way to go. Just expose the fme_basename format attribute on the input DWG features and then use @Value(fme_basename).gdb as the fanout expression in the Navigator, like so:
Note that the DWG has to be split on geometry type, so that all lines end up in a polyline feature class, areas end up in a polygon feature class etc. etc.
  • Sep 6, 2017 9:16 AM UTC
Thanks it is perfectly working.
