modify value of attribute in second position
tnarladni
Forum|alt.badge.img+16
I want to modify the attribute in the second position of an excel. I can get the schema of it and the attribute{1}.name is the actual name of the attribute. But now how do I put in a new value because attributeManager, or tester expects you to know the attribute name and I wont have that.
Forum|alt.badge.img+39
  • November 1, 2019
You should be able to do this with an AttributeCreator, because the attribute already exists it will essentially overwrite the attribute
tnarladni
  • November 1, 2019
you genius you! Thank you @ebygomm
