modify value of attribute in second position
  • Nov 1, 2019 7:10 PM UTC
  • 44 views
tnarladni
Forum|alt.badge.img+24
I want to modify the attribute in the second position of an excel. I can get the schema of it and the attribute{1}.name is the actual name of the attribute. But now how do I put in a new value because attributeManager, or tester expects you to know the attribute name and I wont have that.
Forum|alt.badge.img+54
  • Nov 1, 2019 7:22 PM UTC
You should be able to do this with an AttributeCreator, because the attribute already exists it will essentially overwrite the attribute
tnarladni
  • Nov 1, 2019 8:03 PM UTC
you genius you! Thank you @ebygomm
