merge list elements by index and concatenate
  • Jan 21, 2019 4:37 PM UTC
  • 564 views
This might rather be a simple task, but so far i have no clue how it works to merge and concatenate joined_list elements.
I want to concatenate the two element values into one string and at the end write all the list elements out into one attribute.
Result should be {KA:28,KA:12,KA:4}
gio
Forum|alt.badge.img+15
  • Jan 21, 2019 5:17 PM UTC
if you like to stick to transformers (rather then diving into some snaky script)
you could just explode the list and string-concatenate depthto and strat. As every index in the list is a record.
Then rebuild the list (list builder, no group by) with these concatenated items and use listconcatenator to create one attribute.
Finally, stringconcatenator to get the curly braces on.
Forum|alt.badge.img+54
  • Jan 21, 2019 5:32 PM UTC
But if you did want to dive into some snaky script, something like this in a python caller would work
import fme
import fmeobjects
def concat_list(feature):
    depthto = feature.getAttribute('_join_list{}.depthto')
    strat = feature.getAttribute('_join_list{}.strat')
    for i, val in enumerate(depthto):
         feature.setAttribute('newlist{'+str(i)+'}.newattribute',depthto[i]+strat[i])
  • Jan 22, 2019 10:15 AM UTC
Alternatively, XQuery can also be used, although it's not XML operation.
XQuery expression:
let $start := fme:get-list-attribute('_join_list{}.start')
let $depthto := fme:get-list-attribute('_join_list{}.depthto')
for $i in (1 to count($start))
return $start[$i]||':'||$depthto[$i]
  • Jan 22, 2019 11:20 AM UTC
thanks for the two variants, both of which work great - have to try out also the xquery...
