Merge and Flag
  • January 22, 2014
  • 5 replies
  • 25 views
I need to merge two files (excel).
I want to retain the common fields, but I want to remove duplicates, but also flag the data sources.
So for Example I have:
Readers
File A
Name, Postcode, DOB
Bob, NG1 1AA, 01/01/1970
File B
Name, Postcode, DOB
John, SW1 1AA, 01/01/1980
Writers
File C
Name, Postcode, DOB, FileAFlag, FileBFlag
Bob, NG1 1AA, 01/01/1970, Yes, No
John, SW1 1AA, 01/01/1980, No, Yes
I can merge the File A and B , simply by using 2 AttributeCreators and 1 AttributeKeeper and a Writer.
The problem starts where I have duplicate entries and want to merge the data. See below:
Readers
File A
Name, Postcode, DOB
File B
Name, Postcode, DOB
Writers
File C
Bob, NG1 1AA, 01/01/1970, Yes, Yes
Anyone know which transformers I need to use for this situation?
Thanks, S.
Best answer by ebygomm
If you wanted to keep the FileAFlag, FileBFlag structure you can use a featuremerger after your attributecreators and connect the Merged, Not Merged & Unreferenced ports to the writer.
Forum|alt.badge.img+31
  • January 22, 2014
I would expose the fme_basename on the readers.
Use a matcher to route all unmatched features to the writer
Route the matched features to a duplicate remover and then change the fme_basename attribute to read A&B before connecting to the writer.
  • January 22, 2014
Hi EGomm, thanks for the feedback.
Not sure I follow the bit where you say I need to change the fme_basename attribute to read A&B before connecting to the writer.
  • January 22, 2014
Instead of having an attribute named FileAFlag and another named FileBFlag I would have one attribute of fme_basename, this would be set to the filename of the file the feature had come from.
So if File A is
Name Postcode DOB Bob NG1 1AA 01/01/1970 Sue NG15 7SG 01/05/1980
and File B is
Name Postcode DOB Bob NG1 1AA 01/01/1970 John SW1 1aa 01/01/1980
the features being written would be
Name, Postcode, DOB, fme_basename
Sue, NG15 7SG, 01/05/1980, File A
John, SW1 1AA, 01/01/1980, File B
Bob, NG1 1AA, 01/01/1970, File A & B
  • January 22, 2014
  • January 22, 2014
That is Magic. Looks to have done the trick.
I will test it out with a full set of data tomorrow and see if it works. Cheers, S.
