Max Features to Log Parameter not Working
  • Sep 10, 2019 5:19 AM UTC
  • 45 views
FME 2019.1.2 build 19630
The Max Features to Log parameter (Workspace parameters or FME Options) doesn't seem to work. The number of logged features is always 20, regardless of setting in the parameter.
fmelizard
Forum|alt.badge.img+22
  • Sep 10, 2019 6:00 PM UTC
Hi @takashi Max Features under Workspace parameters works for me, but the parameter under FME Options seems to have no effect. I've filed FMEDESKTOP-9554 about this.
  • Sep 10, 2019 10:07 PM UTC
Hi @danatsafe, thanks for filing the problem. In my testing, the parameter under Workbench Parameters didn't work when set it to greater than 20.
b19630-max-features-to-log.fmw (Max Features to Log = 100)
b19630-max-features-to-log.txt (Log)
fmelizard
  • Sep 11, 2019 5:39 AM UTC
Hi @takashi That's because the 'Max Features to Log' in the Logger is set to 20 in your workspace. The Workspace Parameter is for ALL logging in the workspace. e.g. If that parameter is set to just 35 and your workspace has 2 Loggers, each logging up to 20 features, the only 35 features get logged.
The parameter under FME Options is applied only to new workspaces which should be seen under Workspace Parameters in a new workspace. The problem reported in FMEDESKTOP-9554 is that the values for 'Max Features to Log' and 'Max Logged Features to Record' (features written to <workspace name>_log.ffs) are reversed.
  • Sep 11, 2019 5:54 AM UTC
Oh, I missed that! Thanks for your clarification.
