In a spreadsheet I need to compare the value of an attribute in record 1 to the same attribute in record 2, then move on to compare record 2 with 3, then 3 with 4 and so on. What is the best method?
Cheers,
Best answer by david_r
the AttributeCreator in FME 2014 has the ability to reference values from prior and/or subsequent features:
