Looping custom transformer
  • Jun 29, 2020 9:58 AM UTC
  • 6 replies
  • 112 views
I need to design the following process:
1. I move the object to a specific point (x, y)
2. I check if it fits in another training ground
3. generate another object with offset (dx)
I repeat steps until dx <1.01
I did it like this:
When I created the loops I got a message
So I click YES and create custom transformer:
But when I start the process I don't get the result from the loop...
Does anyone know the easier way? or knows what I have to change?
oscarwillems
Forum|alt.badge.img+19
  • Jun 29, 2020 10:26 AM UTC
This happens because you have a blocking transformer in your loop: the SpatialFilter. This transformer stocks al incoming points from your offsettter and waits for all of them to collect, hence blocking it.
You must make this SpatialFilter non-blocking, and you can do this by making sure the filter features arrive first. You can ensure this by having the reader for your filter be on top in your navigator (so it reads it first).
Then you can configure your SpatialFilter als "filters first" and have it be non-blocking for each candidate that enters (and loops).
  • Jun 30, 2020 6:42 AM UTC
Can you show me where I have to change it?
daraghatsafe
Hi @tk_st, on the Navigator panel on the left-hand side of your screen you should see the readers at the top of this panel simply click on the reader which you would like to process first and drag it to the top of the panel. ReorderReaders.gif
With a NeighborFinder is the same process?
chrisatsafe
Hi @rodrigo_ferrao,
Correct, the NeighborFinder is also a Group-Based transformer so it will behave similarly when the blocking mode is set to Process at End (Blocking).
You can learn more about the Group By More Parameter in the Advanced Training.
Hi @rodrigo_ferrao,
I am stucked in looping with a feature merger and a neighboorfinder. I tried the idea with no loop and it works perfect, but I need to use about 50 neighbootfinder, so I am trying to loop, but it starts to run infinitily
