Look Up Tables
  • October 24, 2014
  • 6 replies
  • 168 views
danpaoly
I would like to have the attribute values in my source data compared to values in an external look up table and changed based on the values in the look up table and then have the new values populated in a different database.
For example.  Read the Type Column find the value UNKNOWN look at the look up table and change UNKNOWN to UNK and send to destination database.
Best answer by takashi
If the mapping rule is static, it can be imported to the AttributeValueMapper setting from an external look up table. Have a look at the [Import] button in the parameters dialog.
Takashi
  • October 24, 2014
have you looked at the Joiner?
David
danpaoly
  • October 24, 2014
I was looking at the SchemaMapper or AttributeValueMapper tools.  There are hundreds of values that need changed to a code
  • October 24, 2014
Takashi
  • May 11, 2017
takashi wrote:
Takashi
What if the mapping rule is dynamic?
itay
Forum|alt.badge.img+17
  • May 11, 2017
Then the schema mapper is a better choice.
  • May 11, 2017
Thanks Itay!
