Lists aggregate
  • Oct 27, 2016 2:13 PM UTC
  • 6 replies
  • 174 views
pratap
Forum|alt.badge.img+12
Hi All,
I have an excel file with header-1 names and header-2 names. I have used AttributeSplitter and made list for both like header-1_list and header-2_list for each record. Now I want to aggregate the values like mentioned below...
If 1 record in excel contains
header-1_list contains 0,1,2 values
header-2_list contains A,B,C,D,E values
Output should be 15 records which contains 0-A,0-B,0-C,0-D,0-E,1-A,1-B,1-C,1-D,1-E,2-A,2-B,2-C,2-D,2-E as values.
(I have attached sample excel file and my progress work bench to this message for better understanding)
Thank you in advance
Pratap
Best answer by takashi
Hi @pratap, I would use the InlineQuerier to perform CROSS JOIN.
SQL statement:
select t1.h||'-'||t2.h as header
from t1 cross join t2
  • Oct 27, 2016 3:07 PM UTC
SQL statement:
  • Oct 28, 2016 12:20 AM UTC
SQL statement:
another approach:
pratap
  • Oct 28, 2016 6:02 AM UTC
Hi @takashi,
Thank you for the reply, it suits exactly the requirement.
Is it possible to add the xlsx_row_id or unique number to each record?
There are several records as shown in excel file and I want to know which records (of target) represent for which record (of source i.e. xlsx_row_id)...
Thank you once again,
Pratap
  • Oct 28, 2016 6:11 AM UTC
Hi @takashi,
Pratap
In the second approach, the original "xlsx_row_id" attribute will be propagated to the resulting features naturally. Just expose it in the reader feature type.
pratap
  • Oct 28, 2016 7:19 AM UTC
Thanks @takashi, I got it with another approach with feature Merger.
gio
Forum|alt.badge.img+15
  • Oct 28, 2016 2:37 PM UTC
cross join is just a unconditional featuremerge...also known as a certesian product
