List writer feature type names in startup/shutdown script
  • Mar 31, 2015 10:18 AM UTC
  • 70 views
john_gis4
Forum|alt.badge.img+13
I have a workbench which writes to some Esri Geodatabase feature classes and need to run some arcpy commands on each target feature class before and after the workbench completes.
At the moment I am hard coding the target feature class names in the python startup/shutdown script, but would really like to pick these up from the workbench by getting a list of writer feature type names.
I'm thinking it must be possible to list the writer feature type names that are defined in the workspace using fmeobjects?
  • Mar 31, 2015 11:28 AM UTC
HI John
I'm afraid there is no way to get the dest feature type names from a Workspace in FMEObjects.  There is an FMEWorkspaceRunner() class which has a method to get parameters but not feature types names. There might be a way around this if you are writing in dynamic mode but you could only get them in the shut down and not in the start up script. Would that still help you?
Ken
john_gis4
  • Mar 31, 2015 12:37 PM UTC
Ok - seems odd that.
Is there a way to get the path of the currently executing workbench (fmw) file then? I could possibly write some python to read the feature types from that.
  • Apr 2, 2015 8:20 AM UTC
have a look at the internal parameters FME_MF_DIR and FME_MF_NAME, both available at runtime:
current_ws_dir = FME_MacroValues['FME_MF_DIR']
current_ws_filename = FME_MacroValues['FME_MF_NAME']
current_ws = current_ws_dir + current_ws_filename
David
