license error log when an workspace is calling a second workspace
  • May 27, 2016 12:46 PM UTC
  • 75 views
simonstefan
We run a workbench which calls a second (and further) workbench(s), using the WorkspaceRunner Transformer. The job appears finished with success but in logs we get the message:
FME license system failure: FME is not licensed for this machine. Contact your Distributor. Your registration key is x-xxx-xxx-xxx. Program Terminating Translation FAILED.
The process fails on calling and running the first of the embedded workbenches. After failure to run the embedded workbench, the 'parent' workspace continues operating, but doesn't call or run the other 2 embedded workbenches, so appears to have been a successful 'job', but isn't. It then throws the licensing error, however, the Server is licensed and the license expire next year. (information from Engines&Licensing;).
This is a mission critical task, so we're stuck without it being operational.
Thanks,
Stefan
Best answer by david_r
Hi
Is your process 100% based on FME Desktop, or do you have some FME Server in your mix as well?
If you run your master workspace on FME Server, you will have to use the FMEServerJobSubmitter rather than the WorkspaceRunner.
David
  • May 27, 2016 1:34 PM UTC
Hi
David
simonstefan
  • May 27, 2016 4:20 PM UTC
Hi
David
thanks ;)
