Label Internal Angles of a Polygon
  • Jan 24, 2025 5:02 AM UTC
  • 161 views
deanhowell
Forum|alt.badge.img+24
I have a closed polygon dataset that I need to add angle labels to the internal angle.
I just wanted to see if anyone has done a similar thing or has some advice on the best way.
I am using the “VertexAngleCalculator” transformer which gives me the results for the actual angles but need to figure out the before and after lines to the calculate the position and angle of the label so it is just offset from the vertex and angled midway between the before and after lines towards the interior of the polygon.
Best answer by geomancer
Take a look at the PolylineAnalyzer (FME Hub). If the polygon is constructed following the 'Right Hand Rule’ (which you can force using an Orientor) the port AngleBetweenLines provides you with the inside arcs and their angles.
The midpoint of this arc provides a logical position for your label (see the attached workspace).
geomancer
Forum|alt.badge.img+71
  • Jan 24, 2025 9:21 AM UTC
deanhowell
  • Jan 27, 2025 12:07 AM UTC
Thanks ​@geomancer you are an FME magician :)
