KML Writing to multiple layers using attribute filter:
  • Mar 28, 2018 3:58 PM UTC
  • 91 views
jhawks
Forum|alt.badge.img+7
I want to write to multiple kml layers (from a shapefile) by splitting them out by scale using Attribute Filter, not sure how to do the scale rangers in Attribute Filter and also how to write to multiple kml layers. I'm trying to duplicate the scale splitting in the attached image. (created using arc2earth, now trying to use fme).
danilo_fme
Forum|alt.badge.img+58
  • Mar 28, 2018 4:13 PM UTC
Hi @jhawks
You can set in your Writer by attribute Scale:
Results in Google Earth:
Thanks,
Danilo
jhawks
  • Mar 28, 2018 5:55 PM UTC
Thanks! that looks very close, but can I see what your suggesting for the Attribute range filter and connecting to it from the attribute filter? I'm still not quite getting it.
jhawks
  • Mar 29, 2018 1:30 PM UTC
That did it thanks! I just need to do some fancy balloon formatting and this will be done, thanks again!
danilo_fme
  • Mar 29, 2018 1:44 PM UTC
Excellent @jhawks
I'm happy to help you! :)
Thanks,
Danilo
